1 - 20 of 20 Posts
*Chrysler T&C 2004 (3,8 L)
There are 3 cables coming from the ceiling, two of them go to the overhead console, but I can't think of a place where should 3rd one go.
Thanks in advance!
59380
That’s for the auto dimming mirror.
Robertschreiber99 beat me to that answer... Good call.
The mirror in the picture, the one hanging on the windshield, it does not seem to be one though...
My 2002 AD mirror is thicker, and has a light, a sensor, and button below the mirror glass (and no flip lever).
2006 Dodge Caravan SX
The auto-dimming mirrors just don't do a good enough job these days from the vehciles behind you with those blazing LEDs. I converted to a regular flip the tab mirror and the blindness decreased drastically. If you drive at night frequently or in the winter as there is less daylight, the manual flip tab mirrors are the way to go.
2009 GCV SE
Really? in my 09 (I replaced my manual mirror for the auto one) I find that the auto mirror does a way better job then the manual mirror does, it seems to be able to get way darker then the flip mirror ever could.
Hmm,
Wonder if the light sensor on the mirror simply senses the presence of light behind you or if it judges its intensity and auto dim's the mirror to a degree based on the intensity?
Is your back hatch window heavily tinted like my 2002 TnC?
I wonder if a dirty dusty light sensor doesn't judge the light intensity as being strong and doesn't adjust the tinting accordingly.
I believe my driver side view mirror is also 'auto chromatic'. I suppose the information for that is also gleaned by the rearview mirror's sensor.
2009 GCV SE
Hmm,
My 09 will vary how dark the mirror is based on how bright the lights behind you are.
2009 GCV SE
Yep, the main mirror sensor on the center rear view mirror sends a current (according to how much is needed) to the driver door module, then to the driver side mirror. In my 09 the mirror is as dark as the center rear view mirror is, and it also can be lighter/darker based on how bright the lights behind are.
This is the 4th gen forum, thus the 4th gen auto mirrors are horrible. Really glad to hear your 5th gen auto-dim mirrors actually work in your 2009! Can a 5th gen auto-dim mirror work in a 4th gen then? Is the connector plug the same or at least the same amount of wires???
2009 GCV SE
The auto mirror in the 5'th gen needs a power and a ground to work, that's it. There is also a 3'd wire which turns the dimming feature off dung reverse but not necessary for it to work.
The connector is different, but as long as you get the power and ground correct, it will work. The mount on the windshield will likely be the same.
HIJACK:
I looked on the FCA build sheet website:FCA Dodge I did not find confirmation I was looking for.
I have the 2002 auto dim rear view inside.
I notice my driver's side view mirror is becoming discolored around the perimeter and considered replacing it.
My question is if anyone can tell me how to determine if that side view mirror is auto dimming also.
I see autochromatic listed on the dealership parts lists, though some are NLA.
I have the memory mirrors, but doubt that has anything to do with the lens. Mine are heated, supposedly.
Wiring, can I determine anything by looking at the wiring going to the actual glass?
Can someone tell me how to release the glass for changing it? (I knocked it out one time in a reversing accident in my driveway) RH/passenger, hanging by the wire, luckily it popped right back on as if it were meant to be changed easily...
2009 GCV SE
HIJACK:
After going through a 06 GCV owners manual it quotes "Driver's side outside mirror auto dimmer-if equipped This mirror automatically adjusts for annoying headlight glare from vehicles behind you. You can turn this feature on or off by pressing the button at the base of the rear view mirror."
I imagine it was available on some town and country vans, not sure how you'd identify it from a non dimming outside mirror. Possibly find a pin out sheet for the mirror plug and see which wires are for the auto function? The outer auto mirror should get 2 wires which come from the center rear view mirror, a power and a ground.
In my 09, the outer mirror doesn't do as good of a job at keeping the glare away because the edges don't dim. There is about a 1/4 cm gap all around where the dimmer doesn't reach, otherwise I think it does a pretty good job otherwise. And the mirror is darker then seen in the photo, the camera didn't show it well.
Now I've gone and done it... If it ain't broke, don't mess with it.
You know what happened next. I got lookin, then touchin, then prying and pulling...
And while I didn't earn seven years bad luck... I did verify that I have (actually, more than likely 'HAD') the auto chromatic mirror. After I satisfied my curiosity, I tried to reinstall *snap the mirror assy back into place, carefully applying more and more pressure... carefully, easy, easy.
I became aware that I was getting some sort of fluid on my hands... I guess I let the magic juice out of the mirror!
I learned how to (and how not to) remove the mirror glass from the folding door assy for replacement. Had I done it that way, I wouldn't have applied so much pressure (well, any pressure, actually) to make the heated, magic glass assy 'leak'
So, then I watched a youTube video...
59433
59434
59435
Reactions: Michalb
2009 GCV SE
So, then I watched a youTube video... View attachment 59432 View attachment 59433 View attachment 59434 View attachment 59435
Does it dim with your center auto mirror? Or do you have a manual center mirror?
2009 GCV SE
Things can always be replaced, especially with these vans being so many of them out there.
I have broken countless clips, dropped the front headlight, left the front bumper hanging on one fog light (yes it ripped the wire), closed the garage with the tailgate open resulting in a huge scrape by the license plate, and lots more unfortunate accidental things taking things apart or a part of that process.
But at the end of the day, those who "meddle" will learn something. I'm always up to take something apart, to see how it works, why it's not working correctly, put it back together. It's fun, and enjoyable when you get it working again! 3/4 of the stuff I know has been learned this way.
Yeah, well, as far as I used to know.... After dusk last night, I tried it out after I put it back together. I used a flash light to simulate the traffic behind me. My side view (now) will create a halo of tint around the center, and it gets really pretty dark mind you.
I never really had done an 'ops check' on it until last night. So I am unsure if it was working 100% prior to me squeezing the juice out of it. Now I am curious how it works.
Yes, I have been a tinker and 'curious' since as long as I can remember. The kid who takes his toys apart to see what makes them tick. "How does G.I.Joe have a Kung Fu grip?"
I believe my tinted rear hatch window, filters the light from behind, and does not darken the side view as much so i didn't really notice that I had the feature.
I need to make a trip to the salvage yard to see what is available.
Reactions: Michalb
Most of the online parts dealers don't have them. NLA
*note:
What you see in the last pic above IS NOT HOW to remove the mirror. The round section on the mirror pic above, the "tilt tray' should still be attached to the servo. Then the mirror section mounts (and dismounts) from that.
~> If I take my wife's bamboo flat spatula from the kitchen, the one she likes to make omelette, and insert it on the bottom space below the mirror, center. Then gently pry the mirror up in a sliding flat motion, it should raise like a 'key hole' type fastener. It should slide up about 1/4-3/8 inch and stop, then you can have it in your hands.
Careful not to simply pull on the spade connectors, they will likely need to be pried between the slot and tab to slide them off as the tab is not real secure to the heat strip.
*note:
Rockauto maybe? Pull-A-Part ?
I know Rockauto has the heated mirrors in stock and mirrors that are powered and some with memory.
Thanks, I think I checks RockAuto, while they had a listing it came back "Out of Stock"
Ahh, sugar... I was near the U-pull today but didn't think to go that way and didn't.
I have to say, that Snake Road salvage has been getting rather expensive. I remember a time when for the most parts, they used to just give me a pass on little stuff and I would pay fair prices for hard parts.
I wonder what they would 'whack' me for a mirror
1 - 20 of 20 Posts
