1 - 4 of 4 Posts
'15 GC. The 2nd row USB ports (#4 in pic) will not charge/power a device (tried with ignition switch on also). Looking through the fuse list, I don't see one labeled USB ports, so not sure which fuse protects these. Thoughts?
This is powered by the '115volt' switch on the dash, by the 4way flashers
If that is lit up, they should work. If not look for its fuse.
Sent from my LG-H933 using Tapatalk
Thanks for the reply, sirtate.
Just an update for anyone who may encounter this problem: it was a blown M6 fuse. On my van, it is not switched by the 115v switch.
On my 2014 T&C the fuse was good, so I got a new port OEM module off eBay for $35 (>$150 list price) and it worked fine. My grandson will be happy. He can keep his IPad going on those long trips.
FYI, mine didn't need 115V switch on just van on/running.
1 - 4 of 4 Posts
