U11F0-00 Lost communication with left Impact Pressure Sensor ???
30K views 6 replies 7 participants last post by  YotoWerks
#1 ·
Hey guys, I Reset my module and replace all components, after an accident, but I still have this code "U11F0-00 Lost communication with left Impact Pressure Sensor" and U11EB-00. Can you help me to solve this issue, do I need to replace sensor or check connections? whet sensor is this and where is located. Thanks in advance
#4 ·
The impact sensors are mounted to the plastic core/radiator support a few inches below the headlights. They are green with a two wire plug and held on with a small torx bolt. A bit challenging to get to with the headlight in place, and of course to get the headlight out requires removal of the front bumper cover and grille. The two front ones are the same if I recall, so could swap from side to side to see if issue moves with sensor. Sometimes they fail after an accident even if still in one piece.
