Recently purchased a 2010 T&C 4.0 with 155k miles.
I put just under 1000 miles on it and it occasionally starts to skip (rev up like it's in neutral) while shifting between 3rd & 4th. After the 3rd or 4th occasion I got a CEL Error Code P0734: Gear 4 Incorrect Ratio. Diagnostics said it's likely low or dirty trans fluid or a solenoid. Prior owner said trans fluid/filter change at 130k.
Fluid appears fine, not burnt. attempted to check fluid level with oil dipstick hack, unsure on trans temp though (COLD here in Detroit) Added approx. 6oz. of ATF+4.
After adding fluid Error Code disappeared , so did the 3-4 gear issue.
Two days later while doing some running around the Reverse gear goes out completely.
No rhyme nor reason, just gone! No Engine Light / Error code to check.
I'm afraid to add any more fluid. Haven't had the opportunity to pull the pan and check it out yet. Depending on the advice I receive I'm not sure I want to, especially if it's just going to lead to me putting it back together so I can get it to a trans shop.
Any insight is greatly appreciated.
