THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-05-99 DATED MARCH 5, 1999 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH ASTERISKS AND INCLUDE ADDITIONAL PARTS AND MODEL COVERAGE.
SUBJECT: Reusable Automatic Transmission Oil Pan Gasket
OVERVIEW: OVERVIEW: This bulletin announces availability and installation of a reusable automatic transmission oil pan gasket.
MODELS:
1989 - 1995 (AS) Town & Country/Caravan/Voyager
DISCUSSION:
A reusable silicone gasket has been developed to replace the RTV method of sealing the automatic transmission oil pan. Due to more frequent Automatic Transmission Fluid (ATF) change intervals and the possibility of the fluid foaming if it comes in contact with uncured RTV it is recommended that this
gasket be used in all applications.
NOTE: THIS GASKET CAN BE REUSED UP TO THREE (3) TIMES. PARTS REQUIRED:
1 05011113AA Gasket, Transmission Oil Pan, 31TH
1 05011114AA Gasket, Transmission Oil Pan, 42LE
1 05011115AA Gasket, Transmission Oil Pan, 41TE/AE
CAUTION : DO NOT OVERFILL TRANSAXLE. DO NOT ADD OIL OF LEVEL IS BETWEEN: LOWER HOLES FOR WARM OIL (100o F). UPPER HOLES FOR HOT OIL (180o F.).
