I have the dreaded bliking lights on my Temperature Climate Control.... I tried resetting it using this vid: but I still had the problem. Even tried replacing the Temperature climate control unit. Still have blinking lights ... here is what happens: what should I replace next? Is there a temperature it needs to be outside for the reset to work?
The reset should work regardless of outside temp. Can you get any flash codes from it if you try to put it in self diagnosis mode? Last time I dealt with a glitching Chrysler HVAC controller it was a damaged wire going to the defrost motor and the flash code pointed me in the right direction.
