1 - 5 of 5 Posts
A new sound after the van has been parked and driven in the rain for a couple of days: liquid sloshing sound that sounds like it’s coming from the left sliding door sill. Most obvious when barely starting to move, or stopping. It kind of sounds like gas sloshing in a long, low jerry can. I did not drive through a deep puddle. Has anyone heard of this and knows the source of this sound?
doors are obviously hollow inside and they let some water in when it rains
they have little drain holes in them to let the water back out, and sometimes they can become plugged causing the door to fill with water
open the sliding door and see if you can feel the water sloshing when you move it
if you have a stow and go van, look in the holes that the seats go
if you don't have a stow and go van, look in the holes where the seats mount for water
Drain holes plugged in door panel or rocker panel.
Drivin' Maniac
2002 Grand Caravan ES 3.8L
I'd check the F&R door's drain slots first. Use a plastic zip-tie to assure that the holes are clear.
Seen lots of Gen4 vans with 'cancer' in the sliders.
Here's one source of water in the rocker panels:
1 - 5 of 5 Posts
