1 - 7 of 7 Posts
Hi All, just bought a used 2013 T&C. Tried to use the searched info to shut the flashers off when opening the sliding doors (ignition on/off 4x, then turn on flashers) to no avail.
Is there a different method for a 2013? I feel like I work for Amazon every time I open a door...
Any info appreciated!
Does yours have a DIC with settings and info? If so, it's in there.
Please humor me, I just got the car yesterday. I went from a relatively low technology 2006 T&C to an advanced (for me) technology I'm still trying to figure out..
What is a DIC?
DIC is the old term. Digital Information Center
Now it's called the EVIC, Electronic Vehicle Information Center.
Both of these are the screen in the middle of your gauge cluster.
When the key is turned but the engine is off, you can use the buttons on the left of the steering wheel to scroll through the menu. The settings menu is disabled unless engine is off and is at the bottom of the list.
What is a DIC?
Since your vehicle is a T&C, you should have full EVIC.
Turn ignition key to acc.
In your steering wheel click on "back" on the left side.
Now, arrow down to System Setup, click right arrow.
Arrow down to Flashers w/Sliding Door.
Right arrow and you're done.
Click back and arrow up to Vehicle Speed or whatever you want.
The engine can be running, but the van has to be in park, I believe. I do it on occasion.
Reactions: CaptMax and Sienile
1 - 7 of 7 Posts
