"So IMO - driveability/center of gravity issues aside - not a good idea to raise this style suspension."
Go tell that to Braun Entervan then. They lift vans this way. It works, and I don't see those vans getting into accidents because of it. I know, there's the expression "Just because it works, doesn't mean it's right." There are trade-offs, and I accept them.
Yes, the front end parts are at different angles now. At least all of my used joints are now operating in different areas than where the wear was, so should actually be tighter than before. I also have spare used parts on hand if something does wear out, and I know how to change them myself. When I did my lift, I did loosen the front control arm pivot points and set the control arms on jack stands, then put the weight of the van on them, bounced it, and tightened the bolts to get the new "road attitude". When I swapped my front hubs, I switched them side-to-side so they would wear on a different part of the stationary race. I run front wheel spacers so the wheels clear the calipers. They also put the wheels back out to where they would be stock width (or more) for stability. The van drives better than it ever has, since it had worn out, crappy quick struts in it before that would bottom out and make the tire rub the fender. I also try to keep the gas tank full to have more weight lower, plus I have the extra weight of the AWD drivetrain under there. I thought this through before doing it, and also made sure everything is bolt-on so it can be reversed if it didn't work out.
While I'm at it, did anyone mention lifting the rear using blocks and longer bolts between the front leaf spring mounts and the body? It's an easier way to lift than helper springs, and it keeps the stock spring rate the same.
