1 - 13 of 13 Posts
2014 Chrysler Town and Country
Hello all. I have a 2014 Town and Country with a 430 RBZ radio. The other day I had my phone charging on the radios USB port. When I disconnected the phone my husband heard a pop and then the radio completely shut down. I checked the fuse under the hood and it was fine but I replaced it anyway. It still isn’t work. Any idea what the problem could be? I’m pretty handing so I have removed the radio from the van.
RIP radio. That port is not for charging, only memory sticks. Unless you know a good electronics repair guy, you need a new radio.
Radio is not a phone charger .no no no
I'm not 100% certain, but what's happening is the power circuit of the USB is overloaded and when the load is disconnected it suddenly discharges back to ground. Like a hammer striking a nail and suddenly the nail is gone and you have a hole in the wall. :p
Reactions: Michalb and Pgh_AL
Discussion Starter · #7 ·
Do you happened to know if I can upgrade my current radio 430 RBZ to a 430N?
Yes, you can. I think it should be a drop in replacement.
Reactions: AmberC3709
Discussion Starter · #9 ·
The old radio was pretty easy to remove just a few plugs. I’m hoping the radio with navigation will work. Thanks for your help.
I've connected my phone to the USB port to transfer MP3s before. Can't remember if it attempted to charge at all, but I had no issues unplugging. It was connected for a while.
2009 GCV SE
Check your Private messages Plz.
Also, the NAV radio (should you get it) will need a NAV antenna. On older vehicles it's the nav plug and it sits just aft under the main dash. As long as it's right side up should be just fine.
Discussion Starter · #12 ·
I have the uConnect system with satellite radio. Will I still need anything else?
2009 GCV SE
Just the antenna for the NAV if the radio you buy has the NAV. You can buy an aftermarket antenna that sticks to the air vent under the dash, or you can find a factory one that screws into the dash.
1 - 13 of 13 Posts
