1 - 20 of 29 Posts
2008-2010 Radios
Media Center 130 (RES) - AM/FM/Single CD Player/Aux
Media Center 130 (RES + RSC) - AM/FM/Sirius/Single CD Player/Aux/Sirius(?)
Media Center 230 (REQ) - AM/FM/Sirius/6DVD Changer/Aux/Sirius(?)
Media Center 430 (REN) - AM/FM/Single DVD/Aux/HDD/Sirius(?)
Media Center 730N (RER) - AM/FM/Single DVD/Aux/HDD/GPS/Sirius(?)
Discussion Starter #2 (Edited)
2011+ Radios
Media Center 430 (RBZ) - AM/FM/Single DVD/Aux/HDD/Sirius(?)
Media Center 430N (RHB) AM/FM/Single DVD/Aux/HDD/Garmin GPS/Sirius(?)
Media Center 730N (RER) (limited availability) AM/FM/Single DVD/Aux/HDD/GPS/Sirius(?)
Media Center 730N (RHR) (late availability) AM/FM/Single DVD/Aux/HDD/GPS/Sirius(?)
Discussion Starter #3 (Edited)
Discussion Starter #4 (Edited)
How-To: Update your MyGIG
If you are experiencing problems, or just want the latest release, this is how to do it.
Install Video:
Its a good idea to watch this video once if you are hesitant to do this update.
Items required:
  • MyGIG RER or REN Radio
  • Blank CD-R
  • CD Burner
  • About 15 minutes
Instructions:
  1. Download the appropriate update for your MyGIG from mofv.com
    RER MyGIG
    REN MyGIG
  2. Burn the update to the CD. Make sure the 3 files are in the root directory of the CD
    Instructions
  3. Start your car
  4. Insert CD into your MyGIG
    Further Instructions/Screen Shots
  5. Select Yes on update screen
  6. Wait for Install process to complete.
  7. It is complete after it reboots the MyGIG on the last time and it asks if you want to update the MyGIG to the same version. Hit "No" and eject the CD
More information, and a dedicated MyGIG forum - http://mofv.com/mygig/
Where do we get updates now? The mofv site does not even list the RHR and has not updated anything in months.
I just bought a 2013 T&C. I wanted the 430N but the dealer didn't have one with the other options i wanted, like a sunroof. Since you can't add a sunroof later, i chose to go with the sunroof and forego the 430N, with the information the dealer gave me about it being easier to add later than the sunroof. I call the dealer and ask if I can swap my 430 for a 430N and pay the $895 option difference. They told me it was going to cost $2300!!! Is that ridiculous or what?!! And he admitted there is no labor involved. Just pull out the existing and plug in the new one. It's the cost of just the radio. Since this is a Chrysler product, I can't go anywhere else. Does anyone have any suggestions. I'd really like to have the factory one but that's ridiculous.
Discussion Starter #8
Mopar recently posted some videos regarding operation of the 430/430N and 730N radios
430/430N (RBZ/RHB)
Introduction
Controls
Phone Pairing
Voice Recognition
USB Inputs
430N (RHB)
Navigation
Great Posts....
as i know nothing about these things i beleive you said i could goto the RBZ does it play dvd movies right on the deck?
Can you use a 2011+ head unit in a 2008-2010 vehicle?
Discussion Starter #14
As far as I know!
One thing to be aware of, is that in 2012-ish they added security PINs to the radios, so if you are buying used, you will probably need to get the PIN from the seller. You know you will need the PIN as there will be "ANTITHEFT" on the faceplate of the radio
Great! Thanks for the info. I wasn't sure if there were differences between the years i. e. high vs low Bus speeds etc.
As far as I know!
2013 Chrysler Town and Country Touring
So, other than the security PIN, is switching out a 430 and installing the 430N just a plug and play swap?
Wow. Good to know this. My original in my 09 t and c is so wonky and it was updated. If I put the connect on an incoming call I can count to 4 slowly before it connects. And around 9 sec to work with voice to text on my phone Smh. Any thoughts on a unit that will plug and play and give Bluetooth music as well?
Does anyone know what kind of fakra connector has rhr head unit side i found a radio with the fakra connection broke and im thinking on soldering a new part or if i can use the sirius module from my ren 2008 to an rhr 2011 both high speed anyone know if it works or have a pic of the internals on rhr unit? Thanks in advance
1 - 20 of 29 Posts
