1 - 4 of 4 Posts
I'm ticked off because discount tire put my lug nuts on back in April so damn tight I can't get them off. Used a breaker bar - stripping them, soaked them in wd 40, nuttin'. One came loose. Any other ideas (other than going back to dt)?? The 19mm slips off most of them now. Pound an 18mm on em? I'm going to have to replace most of them now. Peace.
Get one of these, CTA part number 4221, double ended Lug Nut Flip Socket - 18.5mm on one end and 19.5mm on the other, I bought one at my "local" Autozone, Advance Auto also sells it.
Designed to service 19mm lug nuts with missing or distorted caps found on GM & Chrysler vehicles
18.5mm size fits 19mm lug nuts missing chrome cover
19.5mm size fits 19mm lug nuts with damaged or distorted caps.
Reactions: SMPro
Are they aftermarket lug nuts? Stock or aftermarket wheels? If stock, I replace the capped factory nuts with solid ones, either chrome solid ones or GM nuts with the external threads for screwing on the plastic lug nut covers.
Reactions: SMPro
Thanks --- all stock as far as I know. Never have I been unable to remove a lug nut. Disc tire must have just slammed them back on as hard as possible.
1 - 4 of 4 Posts
