1 - 3 of 3 Posts
Does anyone know how to remove the B Pillar Appliques (Black vertical trim on the door) without damaging it?
Welcome.
One screw on the bottom, inside the door.
It is also hold with double sided tape, it should be loose already.
To re-attach, use black liquid urethane instead of tape (the one used on windshield). Use black RTV of urethane is not available.
Thank you very much. Worked like a charm and the faded colour matched perfectly to our van from the junkyard vehicle.
1 - 3 of 3 Posts
