101 - 102 of 102 Posts
Discussion Starter #101 (Edited)
ATF Level Check with AppCar diagFCA
After my 15 minute drive home, my ATF reached about 138F. Using the app, the table and a ruler I confirmed that I am about where I want to be - close to the maximum level. Van shifts and drives beautifully. I'm a happy camper now with fresh, clean fluid at the correct level, new filter and no leaks (fingers crossed). I'll keep checking the pan occasionally to be sure.
60222
60223
Dipstick is flush with the end of the ruler. The angle makes it look like it's not.
60224
Discussion Starter #102 (Edited)
Power Steering Fluid
Drained and filled about 20 times. I went through almost 2L of ATF+4. I drove the van back and forth turning the wheel from lock to lock each time I refilled to make sure I got as much out of the rack as possible. The fluid wasn't bad but much cleaner now. Pics shortly...
60238
Bottom is old fluid, upper right is new fluid, upper left is after the swap out.
60239
