21 - 23 of 23 Posts
CB2, meant root cause for the current forum thread.
Just FYI, I moved all the harness away from the hot manifold around 2005 per forum advice. No harness issue after changing all the heater hoses in that area ~2010 while likely bumping that harness. No issue in 2015 when the plastic reducer cracked. Then when the reducer failed again in 2018, I immediately started stalling (even at high speeds) plus throwing tranny and throttle codes. That 2018 harness movement made Swiss cheese of the insulation-like good bbq falling off the bone so degradation was just slowed, not stopped, in my situation.
I replaced with a new freebie harness so only time will tell, but I did wrap it with metal foil tape to reduce radiative heat transfer so no longer a black body.
I recall hearing or reading somewhere that the original harness insulator grade was substandard for this application, but I doubt dodge would put that in writing. More to this point: has anyone had to replace the main harness under and connected to this troublesome injector harness since that may have had a different grade insulator, albeit it might be cooler down there?
If it runs well at WOT only and not anywhere else, peel open that harness insulation and inspect! That is exactly what a friend's 2001 AWD van did, and a shop wanted to tear the heads off the engine because they couldn't find the problem. I searched on this forum, got a different harness, went to their house and replaced the fried harness for $20 and amazed the heck out of them. Glad that harness didn't damage the computer, because it can.
I think we are on the same page Buff, just confused on my wording.
I believe that if you replace the harness and put it right back where it got melted the first time, that it will melt again.
If you use a less expensive alternative part, and install it the way Chrysler originally installed it, it will likely melt again, but even sooner this time.
Shielding, insulating, and repositioning are steps I would recommend to prevent reoccurance.
21 - 23 of 23 Posts
