1 - 4 of 4 Posts
Well, first of all, My van was running alright yesterday. Then this morning there was transmission fluid leaking from the van. What might be wrong with the van
Can anyone help me with this one or not??
Maybe with a little more information, like what year is your van and which engine and transmission does your van have. Also where are you seeing the leak?
Anybody work on your van recently with the wheels off the ground? Could be spilled power steering fluid (same product as ATF+4 transmission fluid).
Are you sure it's not coolant?
Power steering hoses can spring leaks, so can the small pipes on the steering rack (corrosion).
Lots of possibilities, need more information and pictures of leak location on the ground, if possible.
1 - 4 of 4 Posts
