21 - 24 of 24 Posts
Sorry, but we're talking about body rot, and not covering rust. Which is why I'm warning the OP, about the structural integrity of his van.
There's a Naval expression about 'urinating into the wind', but hey, someone has to say it.
Isn't that "against the currents" for a submariner? :)
We are currently at 295K+ miles on our 01 DGC EX. I do all my own maintenance and rust repairs. Here is what I recommend from my experience.
1) Our fuel pump went out at 265K miles while I was driving on the expressway, in the rain, at 1 am in the morning. This was the only break down we have had.
2) We are on our third water pump. I change the water pump, inlet pipe and thermostat every coolant flush.
3) Check to see if you can lower your spare tire. The locking clamp will rust into place, preventing the tire from lowering. I bent locking clamp back so it wouldn't engage. Haven't had a problem since. (That was over 15 yrs. ago)
4) Check the power steering cooler hoses for hardness. (Located just behind the rack and pinion) I would only use OEM hoses because of the bends in the hose.
5) Check the transmission cooler, located between the radiator and ac condenser, to see if the pop rivets came lose. You'll know because it will be handing down. This can wear a whole in your radiator.
6) Change the power steering fluid reservoir. This will prevent starving the pump if the filter gets clogged.
7) Transmission filter/fluid change. Only use ATF+4 fluid.
21 - 24 of 24 Posts
