1 - 20 of 56 Posts
2011 Town & Country Touring L
I'm looking to drop a intake into my 2011 T & C Touring L. Has anyone found a intake that will work?
K&N only offers a drop-in air filter.
There's also this: 2011-2014 Chrysler Town & Country ECU Tune
That's not what I'm asking about, what I'm looking for is the whole system, that only gives you 4 or five horse power, but thak you. When I finish what I'm working on I'll post everything from start to finish
For the tune, I'm going with an Halteck ecu.
Discussion Starter #4 (Edited)
Thank you for the reference to RPM, they are what I'm looking for!
Will update on progression of my build.....
Check out "Sienile" on the forum, he has built an aftermarket cold air intake. Technically the factory air intake is a cold air intake. It feeds from below the bumper beam on the right side. Personally, I would like to do a resonator box delete. Some dyno tests on the last chrysler 200, show a 5 hp increase with deletion of the intake resonator. I really like what this person did.
57426
You can also change the lower intake manifold. The latest 3.6 manifold on Grand Cherokee has 20% larger ports. You can find info on Jeep and/or Charger forums. I believe I read it was worth 5 to 10 hp on a dyno.
5 hp improvement is going to be hard to feel. But the two mods combined together, might be a noticable improvment.
Discussion Starter #6
Nice, RPM in Arizona will build a custom intake system and paint it to match the exterior color, u should check them out...
Check out "Sienile" on the forum, he has built an aftermarket cold air intake....
I'm not so sure about that, he refused to post pictures when asked, claiming he was so busy to take pictures.
Maybe he is so ashamed of how it looks like or, it looks so good that he doesn't want anybody else to have it, or maybe he already posted them but I missed them, who knows.
And, if he actually made one, it wouldn't be an "Aftermarket", it would be a "custom" one.
Until he post pictures.....
Discussion Starter #8
Cool, thanks
Any difference to throttle response or engine sound?
Asking for my grandma of course.
Based on this, I already know his answer:
What holds the filter end up in proper position, beside gravity? How much louder, more powerful and fuel efficient is it now?
2013 Chrysler Town and Country Touring
It's not.
I tried to find out the other day. Where does the air come in for the stock air intake? I assume up from underneath but I failed to find out for sure.
The OEM air intake draws from just below the right hand side of the impact bar, just above the fog lamp. I always want to open up the grill around the fog lamp and provide more blown in air. But with my luck, I would find a flooded road and regret it! LOL!
Proof that the OEM stock intake IS a cold air intake, better (colder) than the one's pictured in this discussion.
Reactions: guyonearth
1 - 20 of 56 Posts
