1 - 9 of 9 Posts
Hello I had the PCM replaced at a shop then a month after that I started getting the codes P306 and P206. The shop was no help and couldn't really tell me what it was only that it may cost $1400. So started doing this myself. I've change all 6 fuel injectors, replaced ignition coil and fuel wiring harness and spark plug wires (I couldnt get the actual plugs out). The 306 code is gone, but the P206 remains. White smoke also comes from the exhaust. Hopefully it's not a head gasket. Any sugestions?
How does it run?
Mike S Grand caravan 3.3
Drivin' Maniac
2002 Grand Caravan ES 3.8L
P0206 is an injector wire issue. Is your van pre-mid 2004?
obd-codes.com said:
P0206 means that the PCM detected a fault in the injector or the wiring to the injector. ... When the injector is switched off, the PCM expects to see a voltage that is close to battery voltage or "high". If it doesn't see the expected voltage the PCM will set this code.
Here's the definitive article on this issue....
It's a 2003. I changed the harness ( with a new Dorman model I got from Amazon). The old one was indeed fried.
Now, simply changing the harness will only work for a while unless you took measures to ensure that the new harness is not exposed to the exhaust heat.
Did you install the new harness in the same position as the old harness?
Discussion Starter #8
I replaced the wiring harness with a new one, but still getting that code:(
What happens, and I'd be surprised if that article / forum thread didn't cover this, is that the harness will melt and short circuit one of, or a few, injectors. If it continues long enough, it will kill those injector circuits in the computer.
That is when it starts to get real expensive.
Dorman made a replacement harness, but I doubt it is a superior harness.
Myself, I used some heat reflective tape and re-positioned the injector harness so it was away from the hot exhaust manifold.
1 - 9 of 9 Posts
