Another possibility not mentioned is if the battery is up to snuff. The battery has a normal runing & not running Volts DC readings. I've had a lower reading not-running & had the cruise control go offline. I'd press the steering wheel cruise control button & after about 5-seconds the instrument panel "Cruise" light would go out. Cruise control was then off.
I cleaned all the battery, starter, alternator, & engine ground wires' "terminations". The system still didn't work but the starter sounded better. Then I replaced the battery and cruise control started working.
Cleaning the right wires & checking the battery's output could help. It's more labor intensive but could be less expensive if the wires' "terminations" just need cleaning.
