1 - 4 of 4 Posts
When I start my van in the morning cold I hear coolant swishing through the heater hoses in the dash. I tried 4 time's to let it run and get the air out and it sits and sits there running, heater is hot temp is normal and no cooling fans. They come on with the ac but not with the heat, it's not overheating
Sent from my SM-G950U using Tapatalk
2009 GCV SE
Is the coolant topped up all the way? Some people mentioned sounds from the hoses but it turned out to the the AC with low charge, just an idea. I'd top off the coolant and take it for a longer drive, have the main valve open and circulate through the rad, my van the rad valve didn't even open for 15 minutes, and in that time the fans kicked on 4 times. (yes engine temp stayed exactly where it should)
1 - 4 of 4 Posts
