141 - 160 of 164 Posts
2009 GCV SE
If you try that, send us photos. I'm no stranger to soldering.
I'm still kinda new to it, I just don't want to destroy the WCM, in theory it should work, but maybe Steffen can confirm yes or no. The boards are the same, just that one piece is missing
This seems like a great project to do. I already have a Launch X-431 Mini Pro bi-directional scanner, and I am wondering if it is capable of doing what the dealer would be able to do (sales codes and WCM config). I know I can access various body modules and have changed how long the lights stay on after the car is shut off, reconfigured the tire size for the speedometer after switching to the larger 17" wheels, etc. It has come in handy for lots of jobs already and I've helped several of my friends and family. It can program keys and fobs and perform ABS bleed procedures. If it keeps me out of a dealership it is well worth the price I paid for it. I am still learning the full extent of it's capabilities, and it is a wonderful tool for diagnostics.
I ordered the hood switch, but it would sure be nice to have that bracket it attaches to. I am sure I could fab one up if I have to. I have also ordered two 7 button cases. The van is usually 20 feet from the house, and is parked maybe 40 feet from where she works, so the range wouldn't be an issue at all, and my wife would be happy to have remote start that isn't all hacked together. She would like to have it on every vehicle she drives, but I tell her no because I have fixed a few cars that had burned up harnesses as a result of aftermarket remote starts, including one that caught fire inside the dash, but that is a story for another day...
I think after I replace her wheel bearings, axles, transmission seals, and do a transmission fluid/filter change, I will attempt this. Thanks for the info and working through this, and a big thanks to steffen.m!
Discussion Starter #144
With the right part number the bracket is attached. You should find the wiring with the 2-way plug in the wiring harness under the TIPM.
I have this activated on many cars without changing the WCM, also in european cars where remote start is not available.
If this dont work for you then there are 2 possible reasons
Reason 1 : Your car has'nt a hood ajar switch! You must add this (20-25$). The connector for this should be always built in.
Reason 2 : Your dealer has completed 66% of the necessary steps.
1. step: The dealer must add sales code XBM to the vin
2. step: Dealer must start "restore vehicle configuration" and after this step the most dealers think, thats all. But this is wrong.
3. step: DEALER MUST RESET THE WCM CONFIGURATION. Without this step remote start will NOT work, because the setting for Remote Start is still "FALSE" and not TRUE in the WCM. Your dealer can check this in the tab ECU Details --> Configuration of the WCM. If the setting for "remote start" shows "FALSE" then the dealer must do following: Go to WCM, Change to tab "Misc Function", start the Routine RESET ECU CONFIGURATION. He must now enter the 4-Digit vehicle Pin. After this step your WCM will show "TRUE" für remote start in the tab "ECU Details" --> "Configuration". The remote start will now
There is an official hands on from Chrysler for the Dealers.
https://mopar.chromedata.com/RichContent/CDJR/K6861201.pdf
The programming steps are described on page 2 (step 1 and step 2) and on page 28. Adding the hood ajar switch (if necessary) on page 3
I know this is an old post . But does the remote starter add on come as a kit ? If so where can I find the part number ?.
Discussion Starter #146
There is a kit. Contains a wcm with antenna for extented range, 2 7-Button KeylessGo Fobiks, hood ajar switch. Part Number 82212896AC (Key with Chrysler Logo)
Here an example for this kit
Thanks for the numbers for that kit. Our T&C is a 2009. I found it easy to switch the rubber pad on my chrysler logo fobiks to the new 7 button pad with the start label and contact from the 2 generic fobik shells I purchased on ebay for about $15 plus shipping. The part number of the switch I had already ordered was 05026211AA and was around $15 US plus shipping. The bracket I ordered today had a part number of 05026445AD, and was around $8 US plus shipping. There was another part number 05026277AE that may have been the whole assembly together, but I didn't see the bracket included in the picture or description. That one was close to $40 though, so it would make sense if that was the one.
2013 Chrysler Town and Country Touring
I ordered the hood switch parts yesterday. How hard is it to find the hood switch cable under the TIPM?
I'll still need to buy an OBD II adapter and the scanning software for my laptop. Maybe in a few weeks? I'm not changing out the WIN module, it's a WIN module right? I don't want to work that hard to get 300 feet of range.
2009 GCV SE
It's really easy, I shined a light on the lower wiring part of the TIPM looking from the front and I just saw it there, no issues. There is a decent amount of space there, I did have to untangle it from the rest of the wires there, so it could reach the place where the hood switch is. It's funny, my van didn't have the hole to screw the hood switch onto, but even without it secured it won't go anywhere
I don't know if mine has the mounting hole or not. I'll look the next time I can have someone open the hood for me.
Governor Inslee is likely to extend our stay at home order though so it'll be some time before I'll be allowed company to come and help me with this.
I'm at the part where I need to read the WCM PIN but when I select the routines tab it's blank.
Ideas?
That worked. Followed the instructions to the letter. I think the Appcar software is a bit "quirky", but finished the program, including getting the PIN for the car.
Went to take the van for a drive of at least one mile and my transfer seat broke down and I had to stop to fix it. Good thing Clint was here. It took us over an hour to fix the transfer seat. A screw had backed off and blocked the jack screw that moves the seat forward and backward. It would have been a ten minute job had either of us known what to look for.
After repairing the transfer seat, we drove up and down the freeway, parked in my driveway and shut off the engine and took out the fob. With the doors locked I double tapped the remote start button on the fob and the van started. I unlocked the door with the fob as if I were getting in the van, stuck the fob in it's switch and turned it to run and everything worked great.
Thanks all for your help.
It's wet and cold out and will be for the foreseeable future but once the weather dries up I'll shoot a video of me using the remote start.
Can someone provide some help?
I have a 2014 Grand Caravan.
I changed to the 4 button pad on my remotes (it was a basic 3 button with lock unlock and panic) installed a hood switch and followed the app car diag instructions. Everything seemed to work fine including the reconf9g with the code.
Everything looks correct however the remote start does not work.
Any ideas what I should look at?
What version of Appcar are you using? I ran in to trouble because the newer version couldn't do what I needed it to and had to use an older version. I think a menu item was missing in the new version.
Hey James, I saw you ran into that issue so I made sure I had the 1.6 beta version that reads the codes and let's you reconfigure the WCM. So I dont think it's that, it seemed to work.
I was able to complete all the steps on the appcar site.
Just doesnt work when I hit the button. I took it for a short drive after (like exactly 1 mile) did I need to go further?
If you're sure the programming is correct, start by checking your hood switch. Perhaps it's not contacting properly when the hood is closed or simply isn't working. You can use an ohm meter to verify the switch is working, and if it is, hold the hood switch down by hand while trying remote start.
If that works, then shut the engine off, close the hood and try again.
I just redid the remote start set and reconfigured WIN module again to double check that was the issue. Went for a drive, locked it.
Works perfect.
Thanks for getting me to check again. What a great little modification major brownie points from the wife for this one.
