Thank you, now I know where to look to get one!The switch is mounted between TIPM and right fender. The 2-way wiring housing to connect thie hood ajar switch to the TIPM should be in the wiring harness below the TIPM.
I have appcardiag fca and a OBDLINK and the oem remote start kit but can’t where the setting are on appcardiag fca to change. Could you tell me where they are located?you can use "appcardiag fca" v1.6 and an ELM327 (OBDlink or vgate). No dealer is necessary
The key fob itself is a few pieces, one of them is the rubber part with the clickers. This can be purchased off ebay (just the rubber piece with all 7 buttons or selected variations of where the clickers are. They cost around 10 USD, will fit your fobWhere do I find 2013 T&C seven button keyfob enclosures? I've looked around a bit and not found one that's OEM.
Thanks.
OBDLink SXI know nothing about good brands for ODB2 dongles. I'd be using this with an old Lenovo Windows 7 Pro 64bit laptop I keep around for weird projects (Like this), no Bluetooth, what ODB2 dongle with USB would you suggest?
How do you run the win replaced routine with appcar diagFCA?
Yep, you can buy appcar FCA and you are able to activate a lot of things there, but it costs 50$. On top of the hood ajar sensor, you might want to consider the remote start antenna, which increases range of the remote start. Apparently in 09 dodge didn't install remote start antennas, just the normal wireless key antenna. LuckyI ordered and received new button pads for my fobs, easy switch over.
Now I need to buy the hood switch, and the software and hardware to enable remote start. I assume that all I need to do then is just follow your instructions?
I compared a WCM at the auto wrecker yard to one without, I noticed the spot where the antenna plugs into the WCM, the circuit board has these 5 slots it is soldered into, my WCM has those slots there, maybe it would be as simple as removing that antenna connector and soldering it onto my circuit board?Should work without additional antena
