My 3.6 almost has a hundred thousand miles on it. I'm not sure if the transmission was ever service so I've had this vehicle five months now and I want to check the fluid level properly. It has no dipstick but it does have a cap that says dealer use only. I know that's the transmission cap. Is there a way to check the level using the oil dipstick?
Also I'm having an issue with the transmission where are the vehicle goes into limp mode. I assume it does that so as to not damage the transmission. It seems like something electrical as is always the case with newer vehicles.
So I need to check the transmission fluid level just to make sure it's not a low condition because I don't want to drive it until I know some facts. Then I will need to know if I can service the transmission myself in my driveway.
tia
tia
