37k miles
Rear ac isn’t blowing cold air, temperature is around 60°-65°
Front ac is working fine, around 32°-35°
Tested rear blower motor actuators and they are working fine, blower motor resistor and expansion valve are brand new (OEM)
AC lines are fine there are no leaks. Low side line gets cold but the one going to the rear expansion valve is at room temperature (the line is not clogged)
Here is a link with the gauges readings
AC Gauge Readings
My English is not that good, I’m explaining the best I can
AC Gauge Readings
