1 - 3 of 3 Posts
Hello everyone,
A few weeks ago, I spotted a green spot behind the passenger side rear tire. After a few days when the AC cooling was very weak (now totally nonexistent), It was not difficult to realize that those little green spots were related to A/C.
I figured it is just some stupid o-rings that I can change when I get the time. I read some posts online and watched some videos on Youtube about the common issue with the rear evaporators on these cars. The most interesting video of all is this
. It does look like a hassle but I don't want to cut the lines and cancel the rear AC and, definitely, I'm not taking this to the stealership. I will do it myself as I have the tools and I consider myself handy with car repairs.
Should I try the expansion valve first? If it turns out to be the evap I will have wasted time and $$ for nothing.
I need your recommendations as to whether I should buy the evap from Mopar or get an aftermarket one. I prefer the less expensive route, of course. However, I do want this fix to last a while as the labour part involved is not simple. Any recommendation if I want to buy the evap online?
Since this seems to be a problem that started from the 4th gen (or maybe even before that), why do you think Chrysler engineers did not find a solution all those years? And why on earth isn't there a shield or guard against splashes and debris for the lines coming into the evap right behind the rear wheel well?!!!
Thanks in advance for your help!
2014 Town & Country
Hello everyone,
....why do you think Chrysler engineers did not find a solution all those years?.......
I’m not an automotive engineer nor do I have any reliable resources that are but I wouldn’t be surprised if these types of “nuisance failures” aren’t intentional.
After your car gets a few of these types of issues, a lot of people would trade their car in on a new one??
Other than that leak, the car has been very reliable.
Could someone recommend whether I should buy the evap from Mopar or get an aftermarket one?
1 - 3 of 3 Posts
