1 - 3 of 3 Posts
Okay my T N C did not come with power mirrors I have went to a junk yard and got both modules the mirrors and the complete door harness for both doors and the new switch can I just install these or will I have to get it program? if I have to have it programed is there a way to wire it with the modules thanks
2009 GCV SE
I'm not sure if you need to program or not, the dealer should be able to program it if needed, you can also buy appcar for your van or Alford and then activate as many functions as you'd like.
Be sure to take lots of before and after photos to compare the wiring and such
Its plug & play.
Only the functions turn signal and heated mirror glass have to be programmed. After MY13 the T&C Limited has power folding mirrors. This function have to programmed also. But it needs an other mirror switch and other door modules too
1 - 3 of 3 Posts
