Hey all, New member here.
I just picked up a 2008 Pacifica Limited AWD with a 4.0L with 130xxx miles on the clock.
It's a pretty clean car with a good service history. Pretty typical maintenance from what shows on CarFax. Whenever I buy a used car I try to determine what maintenance needs to be done or is questionable. So on the list I have a timing belt and driveline service along with all fluids and tune up stuff.
One thing that my wife noticed was taking off from a stop sign the car seems to lag a little like the transmission is slipping. This only happens from a dead stop and only when turning a corner. Straight line it does not happen. The transmission seems solid hard or soft through the gears (autostick). No noise or slipping on the highway or fluctuating RPM. No engine light or codes when I scanned it either.
In going through the service records I found the transmission does not show it has ever been serviced so I have it at the shop for a drain fill with ATF+4 and filter to start....damn sealed trans. They are also going to see if they can duplicate the issue we noticed. It seems to be coming from the rear of the car which puzzles me because it only happens while turning. The records also do not show the PTU has been serviced but the rear differential has been. The shop is an independent transmission shop that actually knows Mopar transmissions. Has anyone had similar issues? Anyone know where to start looking? I have never dealt with a vehicle that has the PTU setup with the overrun clutch in the rear. Also...does the overrun clutch share lubrication with the rear differential on the 2007-2008 or is it separate? What fluid is in each? Gear oil or ATF+4? I know so many questions for this newbee. Thanks for your input!
