1 - 5 of 5 Posts
Hi All,
The rear heating/cooling lines burst from being rusty. I have a 3.8L engine and found the part number 5066524AA but search on the web - the prices are outrageous.
Anyone know of where I can get the aluminum lines.
thanks
Do you need the rear heating? If not, you can loop the line near the front and ignore the rear heat.
Some have used hose to replace the pipe.
Prices:
Reactions: beat_truck
Not sure if this is what you need, but try RockAuto.com
That's a nice price at $84.26 Canadian (w/o stow and go seating) and includes the octopus pipes up front. The pipes are aluminum. I suspect the OP's problem is corrosion at a bracket. A piece of hose, double clamped with worm type clamps plus a little sealant may work. Otherwise, run a hose, strapped to the existing pipe somehow.
1 - 5 of 5 Posts
